Need some help on this one folks, i have an Indy and can't see how to route the pipe from the lower outlet of my radiator. The problem is that
its an L-shape outlet facing upwards and the connection to the water pump will go through the alternator/w-pump belt. will SVA man like this?
How have some of u guys done it.
Pinto water pump is 1 and 1/2 " outlet so has to be reduced to 1 and 1/4 for escort rad.
I've got a piece of pipe out of pump that is reduced to rad size and joined (via ally pipe and clips)to a flexy pipe bent in dog leg towards rad
running under the steering rack.
Pipe is dead tight under rack but i've seen it done elsewhere.
You have u2u
cheers
