Rear Disc Calipers
LBMEFM - 10/5/07 at 08:54 PM
Do you have to fix the flexi hose on a bracket where it joins onto the small brake pipe from the caliper. If so where do you mount the bracket?
Regards
Barry
mackei23b - 10/5/07 at 09:05 PM
Hi there
Rear flexi should go straight to the caliper.
Ian
LBMEFM - 10/5/07 at 09:10 PM
Hi Ian
Thanks for the advice, however, MK supplied me with copper pipes, one longer than the other for the rear calipers, do I not need these then.
Barry
ReMan - 10/5/07 at 09:30 PM
Think you'll find they're for drum setup.
snoopy - 11/5/07 at 06:51 AM
the brake kit supplied fits both the drum setup uses the two small brakepipes about 4 inch long the disk setup doesnt need these as flexi,s fit straight to calipers
LBMEFM - 14/5/07 at 09:16 PM
Hi Lads
Once again thanks for the help
Barry
