Hii all,
could anyone tell me the clerance around the prop and tunnel rails at the gearbox end?
Mine is to be over to one side maybe within 5mm of the divers side (tube k in book) is the normal?
What distances do you have?
Can not seem to get to get more central with out the gearbox getting closer than about 5mm of the foot well on the passanger side (as the gearbox
casting sticks out).
I wonder if some one has a plan view picutre that might help?
Gearbox is a type 9.
Dan
[Edited on 20/5/07 by Bluemoon]
Mine is also a bit closer due to the driver footwell being slightly larger than the passenger.
Rich
