Help with progress
paulmw - 25/5/07 at 10:17 AM
Having completed the foorpan last night on my Indy I am now onto the steering. MK provided me with the column, shaft thingy and rack. I think I need some new gaiters, track rod ends? and a new bearing?
Where can I get these items and any tips would be good.
stevec - 25/5/07 at 10:36 AM
Any good Motor Factors will keep this sort of thing.
Steve.
Colnago_Man - 25/5/07 at 11:43 AM
Sorry to hijack you topic a little.
Did you fit MK owns floor, and if so did it fit squarely on your chassis?
I trial fitted mine last night and it was 5mm too big in every direction! Not sure if this makes a difference once the body work is fitted but still not great.
jacko - 25/5/07 at 12:14 PM
I had to cut my MK floor to fit the chassis
Jacko
paulmw - 25/5/07 at 12:30 PM
Yep, my MK floor was too big. Before riveting I cut off the excess with my jigsaw.
Also, when drilling into the chassis make sure your holes dont foul the welds.
Also, MK only supplied 50 rivets . I needed over 100 so make sure you have enough before applying the sealant
Hursty - 25/5/07 at 02:30 PM
You should get the bits you asked about from the motor factors. For other stuff through the build I used car builder solutions who usually can get items to you the next day. Have a look at their brochure on the interweb
mad-butcher - 25/5/07 at 05:55 PM
Tifosi are ideal for rivets and rivnuts, the more you buy the cheaper they get,
tony
Catpuss - 25/5/07 at 07:49 PM
Yep I had about 40 of the rivets but hundreds of the little ones. Now I have about 500 of the big uns in case anyone needs some. I just bought loads of wide 16mmx4.8mm rivets.
I did mine using rivets at 60mm intervals and use sikaflex. I don't expect the floor pan to vibrate with age
I got the mid bearing for the setting column (rubber grommet, plastic sleve and bush) for 3.50 + post off ebay.
I found the floor pan overhangs about 3mm or so. I'll trim after.
paulmw - 26/5/07 at 06:49 PM
Has anyone got a recomendation for a motor factor around Manchester/Cheshire
