Has anyone got some info on fitting bike carbs to a 2.0ltr. Pinto.
I am think of going down this route but I don't know if this is a good idea or not.
Have you guys got any comments.
Thanks Rob
hello buddy,
i have fitted Yamaha R1 bike carbs to my 2.1 pinto. you will have to have a manifold made unless you are any good at welding and you can make your
own. they are very easy to fit and they seem to do the job well. they are very efficient and give a good performance, well as far as i know, but mine
arn't balanced and my engine isn't tuned yet either
hope this helps
Al
Thank s for the reply Al.
Have you got to rejet the carbs to suit. If so where can I get the info on the jets needed?
Rob
Don't know if its of interest, but contact "Rodocog", he is changing his carbs, so may have the manifold, and carbs for sale shortly. HTH Ray
definitley worth the effort to change we used zx9 carbs and the increase in power, smoothness and economy were significant, they seem to be very reliable as well once set up, they stay in tune and are in expensive when compared to webbers. we also drilled out the standard jets so no need to buy replacements.
You could look here.
http://www.robocog.dyndns.org/knnmanifolds/index.php3
N
Hi I have fitted zx9r carbs if you do a search under my name there is a lot of info + have a look in my photo archives
jacko
Thanks to all for the info. It is looking like
ZX9R carbs would be a good choose. Webers cost too much and take up alot of room.
Thanks again Rob
