Need some advice on how secure or safe my oil line attachment are.
I have metal 8mm oil lines comming off the engine, but need to connect these to my 1/2bsp oil cooler. The ends of the 8mm pipe have been swaged just
like a brake pipe fitting. Can i just buy some braided oil line, slip it over the pipe and hold them on with a jubilee clip? Or do i need to get it
crimped like 'normal' OEM types?
I will then attach to the 1/2bsp oil cooler via one of those alloy elbow connectors from rally design.
If they are solid pipes, replace with flexible braided ones instead.
Try thinkautomotive and ask their advice.
[Edited on 18/7/2007 by nitram38]
Not worth going to your local hydralic/air supplier and getting them to make a bespoke pipe with the correct ends?
