Borrow sierra offset wheels (Nottingham)
Hammerhead - 19/7/07 at 12:33 PM
Hi Guys.
This is my situation:
I am attempting to use some enclosed bodywork on my MK Indy chassis. The wheels I have at the moment are for a lotus 340r which I would really like to use, I have had some hub adaptors made to fit these to the sierra hubs/uprights.
Fronts are 195s rears are 225s.
However the wheels stick out from the bodywork by about 20mm each side.
What I could do with is borrowing a sierra offset wheel (if it's the same at the back as the front, if not I need a front and a rear) to see if it will sit under the bodywork.
If anyone can lend me the required wheels I would be very thankful. I can collect or if you would prefer to be present then thats fine too. I live near Bleasby Notts.
Cheers.
Steve.
[Edited on 19/7/07 by Hammerhead]
bilbo - 19/7/07 at 01:10 PM
Hi Steve,
Is that Bleasby near Southwell? Didn't realised you were so close I've got 5 sierra steel wheels sat in my garage in Bingham. You're more than welcome to come over and borrow what you need. I'll U2U my address.
Bill
Hammerhead - 19/7/07 at 01:17 PM
Thanks Bilbo for the U2U.
Yes Bleasby near Southwell. Interesting that you are using a Rover engine too!
Is saturday between 4:30 - 5 be OK for you?
Cheers.
Steve.
bilbo - 19/7/07 at 01:34 PM
I'm seeing my folks on Saturday afternoon, but I should be back by 5:30 - 6 if that's OK? Alternatively, I'll be in all day Sunday.
Bill
