im looking for,
1) mirrors (which sort, where from?)
2) shocks and springs (what spring rates)
there seem to be varying rates on here
thank you folks
[Edited on 30/10/07 by eccsmk]
[Edited on 2/11/07 by eccsmk]
Choosing mirrors you need to consider if they will make it through SVA, so radius's and visibility through them. Some people have passed with
various superbike wing mirrors. Also CBS do a reasonable selection of mirrors here
As for spring rates cant really help you, but others will need various info like engine choice etc to be able to advise properly
[Edited on 29/10/07 by Duncan_P]
ok i'll scout round for mirrors
forgot to add it's and early indy
running 2004 zx12r engine
as far as i know mk sell 300lb and 200lb springs would these be a decent starting point?
you say 2 dampers do you mean 2 pair (front and rear) if you mean 1 pair were are they for as spring rate depends on location
Tony
get in touch with protech directly very helpfull with advice
sorry meant for front and rear of my indy
would these be any good??
http://www.rallydesign.co.uk/catalog/product_info.php?products_id=5241
just found these
http://www.rallydesign.co.uk/catalog/product_info.php?cPath=1375_1594_1604&products_id=11851
if these are any good i'll order today
MK as far as I know use protech or did when I bought the indy
www.protechshocks.co.uk/
tony
just had a look gaz aren't bad martin fitted them to the original indy problem is they are steel bodied ( f***ing heavy compared to the alloy
bodied protechs) also noticed that they are 2 different lenghts in the ad and I don't think the price includes Vat Snoopy if you are reading this
what is the lenght of the danpers on the indy
[Edited on 2/11/07 by mad-butcher]
thanks mad-butcher
i'll try get hold of mk as i've got to pick my tank up at some point
Hi.
Hein Gericke is a good place to get some mirrors from, they do a really nice black set that are a very nice shape for the GSXR 750. Contact the
Peterborough shop located on Lincoln Rd and talk to the manager he should be able to help.
A good start for the springs is 300 lbs on the front and 200 lbs on the rear. However this is a very large can of worms and every one has different
views. If it is fast road use this set up seems to work pretty well with ztec, pinto etc.
Regards
Grant.
thanks Optimum Balance Products
will try Hein Gericke in the week
