if i have some et15 wheels and i want to fit them to my indy what spacers will i need im assuming the ofset will be thrown out in the right direction with the spacers cheers rob
spacers won't work. you'd need to mill 23mm off the mounting face of the wheel to get the right offset.......and you can't do that.
there'll be argument about scrub radius and bearing wear soon, but i'd be happy to run them if you can bend your cycle wing stays to fit
them and they fit under the back arches.
tom
cheers gutted found the wheels and tyres i wanted as well so the search continues. is that tom pats mate if so hows it going.
