I am nearly finished my MK Indy and have it up on a ramp. I would like to fit the rear lights with it still up on the ramp. I am fitting a 5" multi lamp and would like a measurement. I dont have the car on the ground and that is the problem. Any one out there give me a measurement for centre of lens ie from botton of guard or any other static point. david
Hi Dave,
There is a picture in my archive (292) of mounting the rear lights though not the ones to which you refer. When taking the photo, the measurement was
75mm. But I think the tolerance stated in the SVA is massive! Afterall, look at Ford's Focus, Volvo Estates etc they are WAY HIGH!
tks, for reply it looks as though I have plenty of scope, mine will be slightly higher than yours so I should be OK. Tks again. david
