I am building a locost, but am purchasing an indy rear end (wishbones, uprights etc) for the irs on my car. Can anyone tell me what size open/closed
the shocks are that are used on the indy? I have tried several searches which yielded no results...
thanks,
Ned.
hi ned
mines are 13"( says the cardboard box)
open i guess
+/- 10 " closed ( measured )
alloy shocks btw
regards
Koen
www.zx12r-indy.tk
Just while we're talking about this what do you fine folks use as spacers at the bottom of the rear shocks, since the shock is a lot narrower
than the bracket? I stuck in about 5 washers (see attached photo). Are there supposed to be spacers come with the kit or anything?
Fitted my shocks last week and did the same as you, 5 washers to fill in the gaps. I've seen lots of cars like this at various shows which is why I did it, so I can't see it being a problem.
Thanks Koen, I just wondered what mk use, though guess it will depend on my pickup points and might be different as I'm running a narrower
track..
Ned.
