A short clip from my video' today at Bruntingthorpe,Danny keenan giving a demo ride to a customer,we left the pits at the same time after a lap
he came pass me,only to go into the next corner a little too fast,spining off the track
http://www.youtube.com/paulfisher478
note;click on high resolution for better video quality
That's the corner I came off at too! But I ended up on the inside.
I was fine all day, then I went out for a couple of laps with one of their instructors. He carried a lot more speed in than I was, and braked
later.
So I kept on pushing that one corner, later and later, until the inevitable happened.
I suppose that is the luxury of Bruntingthorpe though, loads of run off!
Mike
I came off there last year , when the track was "damp" ended up on the inside though and broke the starter
I find it quite difficult to get that corner right, dont know wether it's because its so wide?
Only came off once yesterday (well you have to don't you)
got a bit out of shape going through the proper chicane/esses and ended up in the
grass, but no damage this time
Originally posted by ReMan
I came off there last year , when the track was "damp" ended up on the inside though and broke the starter![]()
Only came off once yesterday (well you have to don't you)got a bit out of shape going through the proper chicane/esses and ended up in the grass, but no damage this time
oops
Looked like a fast off that one...
Is that GSXR fited to the new chassis?
Yes Steve new chassis,we were both on slicks,just a case of too fast,his line into corner was good Dannys a good brave driver,I was hitting over
120mph into that right hander,just gear down 6th to 4th to 75mph then back into 5th just after apex,exiting around 85mph,did not look it but the most
tricky corner on the circuit because of the high speed aproach,lots of people spun off there,nice feeling the odd time I got it right though.
As I said, makes me feel a bit better about the difficulty of that corner, though I could only just hit 100 before braking from flat out past the
plane.
Put it into 4th I guess down to about 80? but I am only on T1's
Was a good day, made all the better by the weather
