I´ve just stripped my Sierra and starting to sort things out and got to the wire loom. There´s loads of cable there
The cables I can throw away is fan, heater, some instruments & so on.
Anyone got any tips on what to do and not to do?
if you trace out the wires you do need,add colour code to the drawing,then remove wires you dont need,dont bin them till its all working tho,ps use
split conduit as you can add extra wires without too much trouble in the future
would if be possible for you to send me a copy JohnN?
i'm in the same situation needing to sort a loom
and yes, this is a raply to the post after it
[Edited on 29/11/03 by Staple balls]
Hi, Jonte
Can't remember where I got it from, and not got that far myself yet, but I have a document that describes just what you want. I'll U2U it to
you
JohnN
JohnN
That would be great....thanks
there was a diag on locost owners club site
I've used a sierra loom on mine.Keeps the engine electrics simple.The only things I would add is lie it around the chassis/frame where it is going to run.Tape it every 8" or so.It'll keep it's shape better when you come to fully tape it.Test it before fully tapeing.Test everything.!My Immobiliser caused me grief.
