expansion cap size for indy blade
willgal - 1/6/08 at 11:55 AM
hi everyone
i did a trackday at the weekend went well, but on my last session my cap on my expansion tank blown off and i can't find it, must of not tightined it properly. does anyone know which expansion tank the car is based on, its a indy fireblade and i did not build it myself so i am not sure which cap to get, any help would be great, cheers
Jubal - 1/6/08 at 12:05 PM
It could be anything. Post a pic and see if someone recognises it
marting - 1/6/08 at 01:20 PM
This is the picture of wilgals expansion tank with the missing cap. Does anyone know what car its off so he can buy a new cap.
marting - 1/6/08 at 01:21 PM
rear veiw
worX - 1/6/08 at 01:43 PM
I think I have one, but not to sure where I put it.
Will have a look for you later!
marting - 1/6/08 at 02:37 PM
Thanks mate. I think its off a rover 200 but not sure. If you can confirm this il go out and get 1
britishtrident - 1/6/08 at 03:49 PM
Yes bubble shaped rover 200/25 --
Tank is different shape on the other Rovers ie earlier 214 and 400/45 but the cap is the same -- if buy second hand good idea to check the vent hole in the cap isn't blocked up
Late production MGTF tank is the same but has a coolant level warning light sensor.
75 and Honda engined Rovers are completely different.
[Edited on 1/6/08 by britishtrident]
marting - 1/6/08 at 04:06 PM
Thanks alot mate
worX - 2/6/08 at 07:45 AM
I've not looked yet Martin and will still do so, but a new one from a car parts place will cost you about £4 or £5! You need to get a high pressure one, and you can get one to fit a Rover or a Ford.
