What oil have you guys put into your pintos?? i'm currently using castrol gtx high milage but read somewhere that perhaps its not the best stuff
for the job??
i use halford 20W50
15/40 semi synthetic
same as jacko here 15/40 semi synthetic
^^^^ what brand do you use, does brand make a difference do you think?
They had 15/40 and 10/40 mineral oil in Tesco's tonight 2L for £5.40 Buy1 get one free.
I suppose thats mineral when others are using semi but thats probably what was around and used when the pinto first came on the scene
15/50 in mine at the mo
Castrol Edge Sport 10w/60. Needs it the way I drive it!
the advice I got was: pintos are happy with a wide range of oils
basicaly buy a decent brand if you want decent oil
5w/40 or 10w/40 synthetic and change to 10w/50 if its getting too hot / too thirsty
or just stick to standard pinto 15w/40 semi synthetic
[Edited on 20/6/08 by mcerd1]
