FS: YB Cosworth Engine Componants Clear Out and other
DixieTheKid - 10/1/12 at 08:21 PM
Hi chaps,
Before i put this little lot on passion ford and ebay i thought it would be good to offer this little lot to you guys first as you all have helped me out:
2wd YB Cosworth Crank STD but needs regrind to 0.25mm on the bigend (I can have this done professionally for £50) - £175 unground / £225 reground
205 (2222) YBB bare block c/w caps/journals STD Bore a little ware - £150
205 (2222) YBB bare block c/w caps/journals (STD Bore i think) VERY little ware but slight damage to wear the PAS bracket bolts on (will picture) - £open to offers
2wd Alloy Sump - £100
2wd Plunum & Throttle body - £100
4x4 Throttle Body - £15
2wd Bare Head measuring approx 138.2mm-no caps/journals - £200 (first refusal to Mcerd)
Set of 4 rods (one will need repair-spun shell or can have re-homed and then set rebalanced) - as are £50 (or rods & pistons £125)
Set of 4 Std Mahle Piston in very good condition rings are good too although you should really change them - £100 (or rods & pistons £125)
Jack shaft Pulley & Shaft - £25
Breather kidny - £5
Dipstick guide & bracket - £5
Also coming up for sale i will have a running 2.0l 205 block pinto removed for a P100 showing 149k, 5 speed type9 in lovely condition, used genuine P100/saphire/sierra mk2 front doors rot free, used genuine P100/sierra m2 front wings rot free, P100/2wd cosworth bonnet rott free & grille, P100 atlas axle & leaf springs and a P100 tub which will need work or good for the panels.
All prices are based on collection from Southampton, can post or send via carrier-contact me for pricing. Post you U2U if of interest. Pics to follow tomorrow,.
Many thanks Chris
perksy - 14/1/12 at 10:21 AM
U2U Sent
