Hi, been trying to get hold of two meters of the above. Seems localy that I can only buy a roll for £39. Anybody got a couple of meters they could sell me. Cheers Ray
i planned to buy some after christmas to do my fuel tubing can go halfs on a roll if you like.
Hi Ray
I will pop a couple of meters round to Robin’s so next time you come over to see him it will be there.
I assume you mean 10mm O/D
Later
Grant
Get some ordinary 10mm tube and anneal it.
It's a lot cheaper than buying a roll.
just incase you don't know,
Heat it up, almost cherry red then quench it in cold water.
Like butter after.
HTH David
have you tried Wickes (Builders merchants) I bought a roll to use for fuel line dont think it was too expensive.
Hi Guy's, thanks for all the input, now got some from smudge88. Cheers Ray
