Savage hazard switch to MNR loom
chockymonster - 27/4/07 at 08:21 AM
I'm scratching my head trying to figure out how to wire the savage hazard switch in to the MNR loom.
Looking at the connectors on the sierra stalks I can't see which connectors I need to bridge to fire the flasher relay.
I've got the permanent 12v feed but what should that connect to on the flasher relay?
worX - 27/4/07 at 09:17 AM
what pins are on the relay?
or
what wires are going to the relay?
chockymonster - 27/4/07 at 09:41 AM
Ah, as posted by richie below.
[Edited on 27/4/07 by chockymonster]
RichieC - 27/4/07 at 09:56 AM
Just had a look at the Sierra diagram for comparison. The flasher relay has 3 pins, 49, 49a and 31 wired as follows:
49 - bk/red to pin 49 on the switch.
49a - bk/w/gn to pin 49a on the switch
31 - brown to earth.
Theres also an internal diagram of the switch, Ill try and get a pic up.
Hope some of that helped
Rich
chockymonster - 27/4/07 at 07:53 PM
Ok,
I've figured out what does what.
49 - 12v input
49a - 12v output to stalks
31 - ground
If I connect 12v to the relay like that then nothing happens. If I bridge 49a at the stalks to either the left, right or both indicators then the indicators will flash.
At the stalks connector I have
+12v constant power for the hazards circuit.
Output to flash relay (49)
Input from flash relay (49a)
Left Indicator output
Right Indicator output
So what I need to do is bridge 12v to 49 to give power and then join 49a to L+R
My thoughts are as follows:
On the savage switch use the N/O circuit on one side to join +12v to 49
On the other side join the 12v feed from 49a to the L+R indicator output. I'll need to put a diode in the feed to each of the indicators to stop both lighting up when I indicate normally.
I think I need a beer!
worX - 27/4/07 at 08:14 PM
U2U sent...
marc n - 30/4/07 at 12:59 PM
hi paul you definately need diodes to stop it back feeding and thats as much as i can tell you as our sparky does it all normally and hes in vegas at the moment
best regards
marc
chockymonster - 1/5/07 at 08:59 AM
Using the magic of Worx's diagram I've got it wired up with no diodes and no backfeed.
I haven't had a chance to check it all out completely but it's all looking good.
worX - 1/5/07 at 12:59 PM
cool!!!
chockymonster - 1/5/07 at 06:51 PM
I have checked it all out and it works.
Hazards fire perfectly with no feedback and the indicators on the steering wheel work too!
It's all getting back together again
