s2000 engined chaps.
unijacko67 - 18/7/13 at 11:32 PM
Anyone running s2000 engine and box with 15" wheels 50 ratio on a light weight vehicle. Cheers.
Bare - 19/7/13 at 02:21 AM
popular fitment actually.
Couple of issues though;
the engine is tall.. Very Tall.
It's also surprisingly Heavy.. who woulda thought?
the ECU setup is a uniquely Honda preprogrammed affair.
Sans the oem ecu and ALL the associated wiring it's just a heavy inert lump of mewtal
Difficult to outwit / improve upon the honda ecu setup.. Lotsa $$ solves most problems though.. eventually.
Not my first or second choice of power unit, as a Mazda 2.3/ 2.5 is cheap as chips at a wreckers.
S2kPower - 19/7/13 at 08:49 AM
Anything specific you're looking to find out?
unijacko67 - 19/7/13 at 12:49 PM
Yeah, diff ratio's.
I've put a 4.3:1 in mine and think its a bit too low geared. Having said that if I do hill climb's on sticky tyres it might be ok.
When setting off it tends to spin the wheels a bit to easy and hit the rev limiter before you can throw another gear at it then it does the same again in second so I wondered what you chaps had in yours. There doesn't seem any point in having six gears if the ratio's are a bit out. I'm going to stick it on the rollers to get an accurate top end speed as the speedo is way out obviously.
I've also got a 4.1:1 lsd so that could just make all the difference.
After a bit of driving about and with the tyres hotter it does pull away a lot better with less wheel spin, but the low gears are even closer together as I have smaller wheels than the s2000 and 4.3 instead of 4.1 and the car is about half the weight of the s2000. I could be wrong but recon the 4.1 will give me about another 10 mph in top gear which could be about right.
my wheels are 15 195 50 and diff 4.3. what are you chaps using. Cheers
http://www.youtube.com/watch?v=l0pqQssckIA
[Edited on 19/7/13 by unijacko67]
daniel mason - 19/7/13 at 01:05 PM
id stick the 4.1;1 in and see what happens.
aparently the gear ratios in the honda 6 speed are not ideal for these cars but will still be better than most boxes we use!
S2kPower - 19/7/13 at 01:07 PM
Sounds to me that your tyres are too thin and your compound isn't soft. That's a lot of power to put though a 195
Look at hp/ tonne to try and make it relative. You're what, 500-700kg? less? You're around the 300-400hp per tonne figure, which puts you in gt3/f430 territory
I know the weight is different, but the tyres are suited to match
S2000 guys go up to 4.7 on the diff, and a lot use this with superchargers/turbo's at 500hp+ at the wheels
In conclusion... more rubber!
unijacko67 - 19/7/13 at 01:29 PM
I can't really compare what the s2000 car's are using as they have more weight and bigger wheels 17" or something like that so the nearest comparison is like a westfield type car. My car is around 710 kg. Like Dan says I recon the 4.1 will be better, but I think I'll stick it on the rollers with the 4.3 diff before swapping them. I have also considered building a second axle so I could use the 4.3 on hills and the 4.1 on track.
S2kPower - 19/7/13 at 01:37 PM
If i recall, i think Dan had the R500 wheels on his, which are wider than yours
What tyres are you using?
My point with the S2000's was that yes, they're heavier, but they're using similar gearing with much more torque and power going through the wheels, but what keeps it down is the type of compound and the width of the tyre
Look at the subaru brz. They made the car with thinner wheels to make it more 'fun' i.e. reach the limits of adhesion quicker
unijacko67 - 19/7/13 at 01:55 PM
Yokohama ao48 (M) for road, when warm I can set off without much if any wheel spin, but I'm having to throw gears at it far to quick in 1st and 2nd, but I'm a lot out of touch. You can also have your tyres too wide, we haven't just plucked this width out of thin air (It's a good guess, lol) as I have about half the weight of an s2000, so probably more tyre tread per weight than them s2000 lads.
All I was wondering was what anyone might be using, tried and tested diff wise in a similar car. I've a few tidying up jobs to do so a bit worried about taking it out testing as I'm bound to get pulled and don't want to fall out with pc plod.
Cheers for all the help.
Brett Jones - 19/7/13 at 01:57 PM
I've been wondering about this problem too as I haven't brought my wheels yet. But I have been speaking with PWL who has the MNR S2000 in Germany and he's now upgrading his rear tyres to 215 on the rear using 15" rims.
unijacko67 - 19/7/13 at 02:27 PM
It's a bit difficult to test it to be fair as I also have no pedal stop on the clutch so when its all going sideways and hitting the rev limiter and I should be doing a fast gear change I have to remember not to over press the clutch pedal as it tends to over fill the slave cylinder which seems to stick on, resulting in a slipping clutch under revs and a limp home. The only time it did this I had to back off the bleed nipple on the slave cylinder to relive the pressure. So all in all it just needs a Saturday spending on it then a bit of testing.
This video is I think 4th 5th and 6th as when I set off my passenger hit the record button twice so he missed 1st 2nd and 3rd. So you can see how low geared it is, but I'm well happy with the power plant. This was uphill also.
Cheers.
http://www.youtube.com/watch?v=A5pb19eOzrc
wylliezx9r - 19/7/13 at 04:12 PM
I'm running a 3.6 lsd on 16's, gears 5 and 6 are for cruising only really although it still pulls well in these gears from whatever revs. I thought it was going to be useless and was going to swap out to a 3.9 or higher but I like the ratio and will most likely stick with it.
[Edited on 19/7/13 by wylliezx9r]
unijacko67 - 19/7/13 at 04:38 PM
Many thanks, you can imagine what mines like on 4.3 & 15" wheels. Way to low I recon.
Cheers.
daniel mason - 19/7/13 at 04:47 PM
can you not stick a 4.1 in this weekend and go for a spin? and have you got any more wheels and tyres to try?
what pcd and offset are you running? as my uncle may have some you can try!
unijacko67 - 19/7/13 at 04:52 PM
Not quite as simple as that as two piece axle, I could take the crownwheel of one of my other diffs, and swap pinion. I'll try it on rollers first as with sticky tyres it could be a useful hill climb setup.
unijacko67 - 19/7/13 at 08:03 PM
Hi Dan 108 pcd 38 offset. I could put some 16" wheels on the rear, but not sure what that will do to the geometry. Is it legal to have different size front to rear for road use. It could be a great solution to simply put some bigger rear wheels on for track days. I seem to think it won't just be that simple. I'll speak to Darren who worked out all the suspension set up. Cheers.
beaver34 - 19/7/13 at 09:24 PM
i use medium r888 and put down 260bhp on cold ish tyres with no issues apart from a squirm in first
not a s2k engine though but has alot more torque
about 1.50 onwards
http://www.youtube.com/watch?v=S1gjLPJtAto&feature=c4-overview&list=UU9D-bGRXQ0PQ8ejaPRQc43g
unijacko67 - 19/7/13 at 10:23 PM
Thanks, I got these tyres for a bit of road work and testing so can cope with them for that, they are probably spot on tyres and my gearing not doing them justice. They come good with a bit of heat.
I don't think I can get any other diff options other than the 4.1 and 4.3 installed so hope the 4.1 will be a bit better and give me a few more yards in first and second.
I've spent two years building the car and don't expect it to be instantly at its maximum potential, but for me this is where the real work/fun starts.
I remember (1987)swapping my escort/2ltr pinto night rally car 2000E box after destroying a few for a rocket close ratio gearbox and along with the brakes this was high on the list as one of the best improvements I ever did to the car. Its not all about bhp, but it helps.
Ps the wildwood brakes on the kitten are bloody shocking so another job to sort out. I may have to play with pedal pivot points/master cylinders. All in all just a bit of teething. cheers.
unijacko67 - 19/8/13 at 11:36 PM
I've now got my speedo working correctly via a "Modrify" yellow jacket speedo healer. Took the car out with the sat nav installed to re-calibrate the digital speedo and realised the car is geared about right, I was concerned it was under geared as it hits the rev limiter in every gear even 6th, and I thought it may have only been geared for about 100mph, but it was hitting 110mph in 5th so plenty of legs if I need. Finished my sliding windows tonight and dropped the diff oil to check for metal as quite a lot loose play on prop, but all is well. Put the badges on the rear so all good. Ordered my helper springs today as on droop it all goes slack, but all in all very happy with it all. I still need rolling road and another session on the scales and a load of tweaking on the suspension.
PhillipM - 24/8/13 at 02:42 PM
S2000 is heavy?
We weighed ours before it went in and even with the inlet manifold, etc, still on, it was only 108kg.
That's pretty damned light in my book.
As for traction, well, personally I'm hoping it's still spinning well into 3 figures
