Was poking round a mate's 200sx earlier. Thinking what a nice donor it'd make.
Along comes his big brother who done his best to out do him by buying an extremely tasty looking R33 Skyline. 280BHP (IIRC) out the box, twin turbo,
2.5lt straight 6. He's upped the boost a little and it's currently about 360BHP.
Hmmm, I thought, great donor for the Viento sized type cars!
Anyone know much about them?
James
Originally posted by James
twin turbo, 2.5lt straight 6. He's upped the boost a little and it's currently about 360BHP.
AMEN
Mike
i'm using the nissan s12 engine in my indy
yep 1.8 turbo, sounds quite nice running on mega squirt
never mind the rest of it james, the best bit is the 4wd and electric diffs! Some trick stuff. I think its a good idea, but maybe a bit heavy and expensive.
Would probably be best to make a spacframe chassis for it and use the car as is otherwise. Make a rally car basically.That way you could make it lighter, stiffer and generally faster. And keep all the shiny trick bits that would probably be a right ar$e to attempt in a locost type car.
Judging by what Jaspers interested in as a next car, it might have all ready been thought of
Jason
Altho the Skyline engine is awesome, unless ur lookin for 600bhp i'd say go for the sr20det as its good for 450-500bhp and there is loads on ebay
for the price of an R1 engine
My 200sx has 270bhp and it will get to 60 in 5.25secs so in a locost chassis it'd be ridiculously fast, which is why i'm building an MK SX
after i sell the R1!!
I'm using the Nissan s14 engine (ka24de 2.4L) in my locost. Once I have it running, I'll be swapping it out in favor of a Silvia engine
(sr20det turbo 2.0L).
The skyline engines are sweet, but I would look into the sr20det before the rb25dett. The sr20det is the perfect size for a locost project and can
easily make upwards of 300hp with minor modifications.
Don't do it James Sr20DET is the way to go .....
The Skyline engine would just be ridiculous overkill - and they are much rarer and much more expensive secondhand.
Just get one as your daily driver .....
BTW - I'm gonna go have a look at this bad boy soon if it's not sold.... I'm mean really - would you want to chop it up as a donor
Originally posted by Jasper
Don't do it JamesSr20DET is the way to go .....
BTW - I'm gonna go have a look at this bad boy soon if it's not sold.... I'm mean really - would you want to chop it up as a donor:
My mate's one was £8K for an 'N' reg so cheaper than the 1989 one you looked at!
James
[quote
....... Nice looking cars, but really only straightline monsters.
James
That's nearly what my mate has spent this year on servicing for his R33 GTR Lemans. Nice looking cars, but really only straightline monsters.
Was it not the Skyline, that for years, held the lap record around the Nurburgring?
James
You are kidding - 4WD with active diffs - they certinaly go round corners as well, that's why they been so successful on the track....
Good luck with a special based on Godzilla and his little brothers. IMHO the SR20DE / DET are the way to go, cheaper, simpler, better power to weight potential....but then again 600bhp could be fun!
Not sure what you would use it as a donor for ? if youd make some sort of totally custom chassis then hard to say if it would be a good donor but the
engine simply wouldnt fit in a normal ish sized 7 chassis. Ive put the CA18DET in a Rush and only just managed to get everything under the bonnet,
the bare RB block might, just, fit lengthways but there would be no room for the intercooler never mind two turbos or any of the ancilleries.
Also the front diff is part of the sump, so the engine would have to be mounted waaaay forward if you were also intending on using 4x4 plus this would
also mean it being mounted very high in the chassis to accomodate this setup. As said any of the 200SX engines are good donors though
if anyone is interested in doing an Rb26DETT into a Locost...
you will need to find a transmission from a RWD RB25DET. the Skyline GTR is AWD, so the stock tranny wont work.
i would guess you would need a larger chassis than a 'by-the-book' locost. the RB is a big engine. ive seen an SR20 in a Locost, and i
cant imagine fitting an RB in there.
the two turbos dont stick out very far, but the ancilleries up front are very bulky. and the intake manifold sticks out very far.
i think a normally aspirated RB engine could fit as easily as an SR20. as long as you did Velocity stacks. the RB30E (3.0L straight-6 SOHC) can be
made into a RB30DE (DOHC) by swapping the head from the RB25DE. with 12.5:1 you can make 300bhp
I personally wouldnt ever consider a skyline after seeing one after it hit a tree just down from the plant hire (?) place on the Red road to
Camberley.
Surely skyline inners in a locost would only be fit for tescos car park? I mean could you ever pull away from traffic lights without a tyre change or
two to get enough grip on the 'mac?
I suppose the question that I am trying to ask (semi rhetorically) is how many bhp does it take to produce enough torque on a 7esque car for it to
struggle to find grip consistantly in first. I know this probably deserves its own thread as people may decide to debate the use of the terms bhp and
torque (although I know the difference !) and the effects from wheel sizes, gearboxes and axle diffs.
My zx12r vortx gets squirrelly on toyo 888's in a fast pull away, quite easy to break traction and slide her as well..
