rattling
bracey - 30/3/08 at 01:35 PM
what could cause a loud rattling just above tickover and on lift off in a 1800 vauxhall ohc ,checked pullys etc but sounds internal ,no loss of poke and driveability
thanks
richard
Mansfield - 30/3/08 at 01:52 PM
Is it the same clutch in / clutch out?
bracey - 30/3/08 at 02:26 PM
better check that
bracey - 30/3/08 at 05:54 PM
no difference clutch in or out ???
bracey - 31/3/08 at 07:34 PM
thought better check oil very low infact very very very low so am now thinking knackered big ends etc
what other engine choices do i have that will fit getrag box from manta
cheers richard
david walker - 31/3/08 at 08:41 PM
Because it's pronounced when you lift off it could well be failed big ends. The rattling is caused by the pistons hitting the cylinder head - a function of loads of clearance at the big end!
NS Dev - 31/3/08 at 09:13 PM
vauxhall XE 16v, the obvious choice, or, if you are on a tighter budget (not that they are expensive) then get a 2.0 8 valve vauxhall lump out of a late 8 valve cav sri, they are 130hp as std and bulletproof (as long as you keep the oil level right!) they made them with 8 valvers up to '93 iirc
bracey - 2/4/08 at 05:23 PM
10 points to dave walker ,yep big ends ,good news is have aquired spare engine so hopefully not of road long
just my luck though ,just getting sunny here
