idl1975
| posted on 13/2/09 at 03:00 PM |
Which fuel pump for a 'blade engined MK?
My fuel pump appears to have packed up. In case I can't locate an identical item, can anyone point me towards a pump with the proper flow
characteristics for a completely stock '893 blade engine on the OE carbs, or just the appropriate pressure/flow rate? Sorry if the question is
a bit thick, but I don't want to get the wrong part!
ReMan
| posted on 13/2/09 at 03:05 PM |
Almost any carb'd bike pump should be Ok, Fittings and connectors add to the suitability.
Just don't pay £65.00 for the one on Ebay!
Dangle_kt
| posted on 13/2/09 at 03:20 PM |
I got a blade one off a locoster, but when I fitted it - it was a duff.
It now has a carbed r1 fuel pump and works great.
idl1975
| posted on 13/2/09 at 03:21 PM |
Thanks guys. So pumps from any carb'd bike or something running similar pressures should work, despite the longer fuel run in the car?
Dangle_kt
| posted on 13/2/09 at 04:19 PM |
yup - they just take longer to get up to pressure, so they are a bit noisey when you first use them - they work fine in use.
but I wouldn't use one off a 50cc scooter
[Edited on 13/2/09 by Dangle_kt]
