davy
| posted on 19/4/09 at 01:44 AM |
Height of ground at front.
My MK which I have nearly finished appears to be very low to the ground at the front, I have a fireblade fitted. What ground clearance should I
have. All parts were supplied by MK. Rear is OK. How do I raise the front up. I have the correct shocks fitted.
dogwood
| posted on 19/4/09 at 06:55 AM |
All I can say is
You should have at least 4" ground clearence for road use.
I run at about that and it still touches down sometimes.
I assume you have tried winding your shocks up?
FREE THE ROADSTER ONE…!!
bob tatt
| posted on 19/4/09 at 06:57 AM |
mine is about 90 mm to the chassis at the front. all you need to do is adjust the ride height on the spring platforms by turning them. as you adjust
move the car back and forth to let it settle job done.
rob
