New Topic New Reply
Author: Subject: Indy R rear suspension torque
dan__wright
posted on 25/5/09 at 12:11 PM Reply With Quote
ive got a knock from the rear so im going to go over everything but ive lost my sheet that had a the required torque for all the suspension etc.
can someone let me know how tight i should do the wishbone, upright and coilover bolts please.
mark chandler
posted on 25/5/09 at 06:44 PM Reply With Quote
The bushes will have steel inserts so just bloody tight, you are clamping to metal.
Mine came loose a couple of times so lockite on the buggers now, they had nylocs!
If you have rubber bushes the car needs to be at ride height, if polybushes or rose joints then you can tighten jacked up.
Regards Mark
New Topic New Reply
