New Topic New Reply
Author: Subject: Seat belt anchorage points
40inches
posted on 28/5/09 at 06:21 PM Reply With Quote
Can someone please measure the distance from the bottom anchorage points to the back panel?
I have 90mm, this seems very close, as the points are well behind the seats on mine
speedyxjs
posted on 28/5/09 at 06:28 PM Reply With Quote
Mine are also well behind the seats but that was the only place i could weld them in more than one place
ashg
posted on 28/5/09 at 07:04 PM Reply With Quote
its 140mm on the haynes roadster if that helps
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
Stuart_B
posted on 28/5/09 at 07:43 PM Reply With Quote
hi, do not know the messurements, but there are 2 photos, if that helps you here
stuart
40inches
posted on 29/5/09 at 01:00 PM Reply With Quote
stuart
From these photos it seems that MK moved the mounts, at some point in time, from 90mm to around 160mm. Another job on the list of things to do
Thanks for the help guys.
Image deleted by owner
speedyxjs
posted on 30/5/09 at 07:34 PM Reply With Quote
Why the need to move it?
40inches
posted on 1/6/09 at 12:09 PM Reply With Quote
The mounts are around 150mm behind the harness slots in the seats and put the belt right at the back vertical edge of the slot, probably why MK moved them forward on later chassis, plus, the mount is exactly where the bracket for the starter motor will fit
New Topic New Reply
