EasyJimbo
| posted on 6/6/09 at 12:25 PM |
Fuel pipe and Brake lines
Hi guys
Can anyone reomend what fuel line I need and where I can get this from? Also I have the delux kit from MK which has brake pipes set in but I guess i
will need further brake pipes will I? if so what spec and where is best to get these?
thanks
J
[Edited on 7/6/09 by EasyJimbo]
be gentle I am new to all this :-)
blog: http://mkjimbo-mkindybuild.blogspot.com/
EasyJimbo
| posted on 7/6/09 at 03:57 PM |
Anyone?
Staple balls
| posted on 7/6/09 at 05:49 PM |
Depends what you got in your brake line kit from MK.
Usual fuel line is 8mm copper microbore heating tube + correct marked rubber pipe to suit your engine/fuel of choice.
Hellfire
| posted on 7/6/09 at 05:59 PM |
You should have enough brake pipe to run your brake lines but it ultimately depends on how/where you route it. If you run out, have a word with MK.
With regards to your fuel line, you're better off measuring the existing fuel fittings on the engine/fuel pump and then getting some copper
microbore like Mr Balls says Most good DIY places will sell it. You then need flexible fuel hose to connect each end.
Phil
