stevem2727
posted on 25/6/09 at 06:27 PM |
limited slip diff
I no this has been covered before but i cant find it sorry.How do i no if i have a lsd.Do the rear wheels turn the same way when off the ground or
opposite?thanks.
jacko
posted on 25/6/09 at 06:31 PM |
Same way
Mr G
posted on 25/6/09 at 06:57 PM |
Have a read of THIS thread
stevem2727
posted on 25/6/09 at 08:55 PM |
thank you
Dan
posted on 28/6/09 at 01:02 PM |
welded diff
make sure its not a welded diff as well!!
if you hold the prop flange make sure the out puts still turn with some resistance movement on the prop flange as i found out when went to buy a diff
described as a lsd.
you sould be able to hold the prop and still turn the output shafts with them both turning the same way
flak monkey
posted on 29/6/09 at 07:46 PM |
Ummm, NO! If you did then the diff is broken. With the prop locked (car in gear) any diff will spin one wheel one way and one the other. The
difference is in the amount of force to do it. An open diff will spin the wheels in opposite directions very easily. With an LSD there will be some
resistance, but they will still turn in opposite directions.
With an LSD and the wheels off the ground and the car OUT of gear (prop free to rotate), the wheels will turn in the same direction generally
depending on the resistance in the drivetrain.
If the diff is off the car if you lock the prop and then try to turn the output flanges in opposite directions an LSD is very tight to turn, and open
diff is very easy. (I was playing about with one of each tonight incidently).
The other way to tell (assuming there is no tag - if there is and it has AA in the code then its LSD) is to take the back off and have a look. I can
post some pics of the inside of both types if its useful?
Sera
http://www.motosera.com
