matty h
| posted on 5/12/09 at 09:53 AM |
MK De dion Suspension set up
I am after some guidance on what my MK suspension should be set at caster,camber and toe in/toe out.
It is de dion rear end.
Thanks Matty
billy
| posted on 5/12/09 at 12:56 PM |
your not gonna get much adjustment on the rear end, theres lots of info on the forum about setting up the front end
luego-lo-cost finished,vauxhall 16v 2.0,twin 45s de-dion rear set up
mangogrooveworkshop
| posted on 5/12/09 at 01:06 PM |
Dont talk 541t bet you own an indy.
The rear is shimmed some thing 1 degree toe in and 1.5 vertical.
The best person I know re these matters would be Matt from Procomp.
Mines set like that and its ok.
If you are using the hoop wishbones on the top at the front discard them and get a set of wooshers bones
You will save yourself so much grief in the search for handling.
graememk
| posted on 5/12/09 at 01:37 PM |
as far as i know mat knows his stuff but dosnt like the indy......
how about calling MK and asking ?
MikeR
| posted on 5/12/09 at 03:31 PM |
He'll probably be happier with the de-dion car - its uncle rons old design with a de-dion rear end (which is what i'm doing to mine uncle
ron car so very interested in the results of the thread).
procomp
| posted on 5/12/09 at 07:57 PM |
Hi
Lol it's not that i dont like the Indys as such. It's just that am known for voicing my opinion on what it needs to make one better.
Cheers Matt
mangogrooveworkshop
| posted on 7/12/09 at 09:30 PM |
quote: Originally posted by procomp
Hi
Cheers Matt
Where do we start
Top bones need more caster
the cockpit needs round tubes along the outside and up to meet the rear hoops.
The top seatbelt mountings are way to low
could do with some extra diags in the front suspension box.
The lower bones are a problem if a heavy engine is used
other than that its built to a price and using non custom parts.
Now how much do you know about Birkins with a live axle?
