Jay k
| posted on 26/1/10 at 01:29 PM |
Clutch cable
Hi,
Is 1.35 m long enough for the clutch cable on a MK indy with a 929 blade fitted?
Thanks in advance
ashg
| posted on 26/1/10 at 02:21 PM |
it should be. its almost half the length of the car
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
Bluemoon
| posted on 26/1/10 at 03:50 PM |
Humm as above, not always so easy to loose a long clutch cable (mines o.k but have this issue with my standard sierra speedo cable)..
Dan
blakep82
| posted on 26/1/10 at 05:02 PM |
i have no idea of clutch cables in 7's, but isn't the clutch pedal practically right next to the clutch? i'd have thought about half
a meter to 1 meter would be enough.
if you're using one from another car though, i'm sure you could get away with coiling it up
________________________
gordon h
| posted on 26/1/10 at 05:10 PM |
i used a sierra 4x4 clutch cable both inner and outer are lined, made for a nice light pedal.
bec is best but going to try sabb 2.3 turbo mk
