GeoffB
posted on 6/6/04 at 11:44 AM |
Rear hub fixing bolts probs.?
im having trouble getting the four bolts to line up to go in the rear mk upright,seem to get two in ok,then other two seem5mm out or so,tryed swapping
round,hitting,to no avail..do i just need to enlarge the hols to about 10 mm in the hub carrier or is there another way..?
Staple balls
posted on 6/6/04 at 01:17 PM |
hmm
i don't remember having a problem, i'll try to grab a photo in a bit so you an check if you've got it right
GeoffB
posted on 6/6/04 at 02:54 PM |
thanks for the reply staple balls, ive done it now i had to push the hub and shaft right up agaisnt the back plate then do up the bolts otherwise it
wouldnt go square,,problem is i needed 8 hands..perservance is the best tool..me dad use to say..
Staple balls
posted on 6/6/04 at 03:09 PM |
ahh!
yes, i remember now, it's an absolute bitch that bit, i ended up using my feet to hold the plates back and getting the 4 bolts in loosly first.
