New Topic New Reply
Author: Subject: MK Clutch pedal
Jonte
posted on 16/6/04 at 01:32 PM Reply With Quote
MK Clutch pedal
Here we go again with one of my stupid questions
I´m building with a Pinto and type9 gearbox.
Should it be some kind of spring on the clutch somewhere???
Click it
Mk-Ninja
posted on 16/6/04 at 01:44 PM Reply With Quote
All you need is some adjustment on the cable somewhere so that you can get a bit of free play in the cable / pedal so that when the clutch is released there is no load on the thrust bearing
[Edited on 16:6:04 by Mk-Ninja]
I'm sure I've got one, just don't know where I've put it
Jonte
posted on 16/6/04 at 01:52 PM Reply With Quote
OK
thought I saw a spring on the clutch when I took it from the Sierra.....
Click it
Mk-Ninja
posted on 16/6/04 at 02:00 PM Reply With Quote
The Sierra has a self tensioning/ ratchet mech. All you need is some means of adjustment, as the pedal will try to fall forward on its own. You could put a spring in but Ive not seen one used.
No doubt someone will corect me.
paulbeyer
posted on 16/6/04 at 02:42 PM Reply With Quote
What clutch cable did you use?
7 out of 10 people suffer with hemorrhoids. Does that mean the other 3 enjoy them?
Mk-Ninja
posted on 16/6/04 at 03:13 PM Reply With Quote
I used the bike cable which has adjustment on the engine end. I think MK7 used a cortina cable which has ajustment on the outer cable and fits the pinto box.
Jonte
posted on 16/6/04 at 05:13 PM Reply With Quote
I have the original from my sierra
Click it
theconrodkid
posted on 16/6/04 at 05:35 PM Reply With Quote
you need a cortina/capri cable as the seirra one has no adjuster
who cares who wins
pass the pork pies
mad4x4
posted on 16/6/04 at 09:57 PM Reply With Quote
I buildt my own pedal and used a standard clutch cable (Sierria 1.8CVH). For the adustment I drilled an m12x45 bolt all the way though (down its length) and then slotted this with my grinder. I then welded a small piece of tube to the head to hold the end of the cable sleve. This allows the cable to be adusted at the bell housing end.
I also had to space the plastic bit back from the pedal to get my adjustment correct by extending the tube on the chassis.
to connect the cable to the pedal I welded a m6 washer over an m12 nut. Then I took and m12 bolt and drilled a hole through the length and sloted it with the grinder. This allows the cable to be sliped through the bolt and the nipple can sit in the nut when screwed together. The nut with the washer had two bars welded to it so that a pin could be used to attach it to the pedal.
Scot's do it better in Kilts.
Jonte
posted on 17/6/04 at 05:41 PM Reply With Quote
yeah...right...try to find one of those in this country of Volvos
Click it
Jonte
posted on 17/6/04 at 05:43 PM Reply With Quote
no pics?!?
Click it
bob
posted on 17/6/04 at 09:19 PM Reply With Quote
Jonte
go to ebay and search for clutch cables,always plenty of old ford cables on there including cortina mk3/4/5 and capri
[Edited on 17/6/04 by bob]
posted on 17/6/04 at 10:13 PM Reply With Quote
FWIW, i made my pedal, used a small 19mm od tube to hold the clutch cable sheath (whatever its called...), judged it the right length to not need adjustment, then welded a bar onto the back of the bracket to stop the (bottom mounted) pedal falling forward. Works well, but i got the leverage a little bit too stiff (usable though) and it amplifies the lever effect (lots of resistance at first and then the pedal drops easier, so when letting the clutch out it suddenly springs up under your foot.) still works well though.
Jonte
posted on 21/6/04 at 07:43 AM Reply With Quote
Can I use that without any major adjustments to the cable?
Click it
New Topic New Reply
