Iaing
| posted on 23/12/10 at 01:56 PM |
Winter
This is my first post on here so firstly hello, im the owner of a 1.8 k series engined MK indy R which I bought from PistonHeads towards the end of
the summer (just in time for the bad weather!).
My plan is to spend a bit of time on the car over the winter getting everything as it should as there are a number of things which require some
attention but before then I plan on giving the car a good service.
The car is an indy r chassis and im told has sierra cosworth running gear and gear box with a tuned 1.8k series on TB's. On my list of
to-do's are
- General Service
- Brakes (feel really isn't great, you need to fairly stamp on the pedal for them to bite, maybe normal with the type of master cylinder?)
-Lights (my dipped beam doesn't work)
-Build a gear gate (reverse is far too close to first!)
-Water Temp Gauge / Thermostat (Temp sits far too low on the gauge, could possibly be a faulty gauge?)
Anyway, how does everyone keep their Indy off its wheels over the winter? Just plain axle stands?
Iain
[Edited on 23/12/10 by Iaing]
jossey
| posted on 23/12/10 at 01:59 PM |
Firstly welcome to the mad house.
i use Axle stands on back and a few bits of wood under the front.
Hope you find the site useful. its been priceless for me as im building my locost from a pile of 1" tube and bits from here and ebay.
:O)
good luck with your servicing in the cold.
steve m
| posted on 23/12/10 at 02:19 PM |
Ian
Welcome,
I will try and answer a couple of your questions,
firstly the brakes, i had pretty well the same problem with my locost <<<<, the brakes worked and were up to mot requirments
but i had to stand so hard on the pedal my bum/lower back hurt sitting in the seat, firstly i swopped the cortina standard 2 pots for princess 4 pot
calipers , and that helped, but the biggest improvement in my brakes was moving the master cylinder rod pin 1/2 inch up the pedal, and thus
increasing the fulcrum effect, my brakes are now at a very good feel
This said, that as the locost does not have a servo, nor need one, it does take a while to relearn over drving our tin tops with a servo
Making a gate for the gears is a very worthwile improvement, and one i am also thinking off
as for keeping the wheels of the ground, why bother (i dont) these cars are so light, a doubt it would make any difference,
i normally pump th tyres up to 40psi over the winter, and drop them to 16 when driving
Regards
RazMan
| posted on 23/12/10 at 02:29 PM |
Hi Ian and welcome
Your brakes problem might be the wrong compound pads so try and see what they are before you start ripping things apart. Having said that, remember
you are probably not running a servo assisted system so things are bound to feel scary until the muscles in your leg get used to it Other factors
are m/c dia and caliper piston size, also pedal ratio - get some details and come back - someone's sure to sort you out.
The water temp could be due to running the wrong / faulty / no thermostat so worth checking that first. My engine had trouble with low temps until I
figured that one out.
Raz
RichardK
| posted on 23/12/10 at 02:31 PM |
Ah.... so you're to blame for the rubbish weather are you
I also don't tend to put my car up on stands either, 3 years on, never had a problemo.
Rich
Oh and welcome to the madhouse.
Gallery updated 11/01/2011
adithorp
| posted on 23/12/10 at 04:30 PM |
Welcome to the mad house.
Brakes could beseveral things. No servo does make the pedal feel very solid and takes some getting used to. The Sierra master cylinder is also a large
diameter (due to normally having a servo) and an improvement is to replace it with either an early Mk1/2 Fiesta non-servo master or Fiat non-servo
(Uno/Panda?) one. Different pads can also help as can altering the pedal leverage.
Temp' sounds like the thermostat either faulty or missing. Quite common for people to remove thinking it helps ???
Either put it on stands under the chassis or just leave with extra air in the tyres. Car that light shouldn't be a problem.
http://jpsc.org.uk/forum/
jacko
| posted on 23/12/10 at 07:12 PM |
Blow the tyres up nice and hard if you are leaving it on the floor i blow mine up to 35 - 40 lbs
OOOO and WELCOME to the MadHoUsE
Jacko
Iaing
| posted on 31/12/10 at 12:29 PM |
Hey folks, sorry for the slow reply. I have the festive season to blame! Thanks for all the replies.
Went out to check on the car last night (as you do!) and noticed that i have a nice puddle of anti freeze under the car, turns out one of the coolant
hoses has decided to spring a leak on its own. Brilliant, better add that to the list too!
Iain
