Jim
| posted on 21/9/04 at 01:33 PM |
Noise level from standard Mk Blade Exhaust
Does anybody know the noise level from a standard Mk Blade exhaust. I have a track day booked and the limit is 105 dB. When SVa'd it was 101
db at 5k.
What rev's do people use for track day static tests?
Jim
[Edited on 21/9/04 by Jim]
Mikey G
| posted on 21/9/04 at 01:56 PM |
I showed 102db @7500rpm at Castle combe in august, car is a factory built Stuart Taylor Blade with what seems like a worn out silencer at the mo! you
should be OK i would have thought, 105db is quite loud!
Mike
Jim
| posted on 21/9/04 at 02:28 PM |
Cheers, at the moment the exhaust (redline race can) can be heard about 1 mile away. Will have to change to old Mk one then for track day
Jim
Hellfire
| posted on 21/9/04 at 09:02 PM |
Noise
IIRC ours is a ST exhaust via MK. At SVA first test showed 104Db at 7850rpm when clogging it, it would surely exceed 105Db.
Maybe a bit of packing would come in handy...
HTH
Jim
| posted on 23/9/04 at 10:29 AM |
Interesting. where did you get this from?
DEAN C.
| posted on 23/9/04 at 07:30 PM |
You didnt mention the twenty minutes of hammering,shaping and of course the cursing .Mainly about the plonker doing the emissions tests
admittedly!
DEAN.......
Once I've finished a project why do I start another?
Jim
| posted on 25/9/04 at 12:30 PM |
Been to Mk to inquire about the inserts. Just want to say thanks for the time and the metal tube
Excellent service as usual
Jim
