doobrychat
posted on 2/6/13 at 12:38 PM |
MK Indy rear drive shafts
hi all..
After my post last night about BEC speeds i am searching for a lower ratio diff to my 3.92.. Mine has push in shafts and didn't know if they had
been shortened at all as i got the kit part built..
My diff has push in shafts and many of the diffs i am looking at on fleabay have bolt on shafts so i was wondering on whats what with them, I read on
here you can remove the bolt on stub shafts, is that right?
looking at a 3.62lsd hence my question..
Many thanks in advance..
jacko
posted on 2/6/13 at 06:09 PM |
If your car is a Indy the shafts are standard length of the sierra
Jacko
dave_424
posted on 2/6/13 at 06:20 PM |
I have a 3.62 for sale but i'm pretty sure that it's non LSD, not sure if you could put the crown wheel and pinion from the 3.62 onto your
LSD
£40 if you want it
Dave
doobrychat
posted on 2/6/13 at 07:16 PM |
hi all..
thanks for the info... I have won a 3.62 lsd on fleabay now with bolt on shafts.. i will get some shafts and get it on soon before i take advantage
of ever fuel station on the a2 to get from a-b...
jacko
posted on 2/6/13 at 07:50 PM |
Before you go to far the rear uprights are different on a bolt on shaft axle i believe as they have discs brakes
just do some more checking before going to far
I expect someone will be along that knows better then me
Jacko
[Edited on 2/6/13 by jacko]
