Calzonii
posted on 18/12/14 at 12:29 AM |
FINALLY time to buy my Indy
Havent been on here in a while! 2012 last time... However... The long awaited day has arrived as a newly qualified graduate I have just finished 9
months work and have FINALLY got enough cash to start deciding (once and for all) what to build!
With a budget of £12k between my mate and me we are planning on buying a duratec engine and an Indy R Kit... Has anyone on the forum built this
before? I have rebuilt a few beetles and my mate is a mech eng so hopefully between the two of us we can figure out which way round the engine goes.
Does this kit and engine sound simple enough for first time build?
Just wondering if anyone has any information on speed stats or previous experience builidng and MK with a duratec engine and how they found the
experience? Even if anyone has any linnks to build diarys or any information would be great.
Thanks,
Cal
Alan B
posted on 18/12/14 at 01:44 AM |
Word of advice....
I'm sure your mate is a great guy, but be sure to have something drawn up to cover you both from whatever could happen.
Joint projects can go horribly wrong....
Other than that.....enjoy..
daniel mason
posted on 18/12/14 at 07:34 AM |
Some of the westfield duratecs I've sprinted with have been pretty quick!
INDY BIRD
posted on 18/12/14 at 07:49 AM |
Some good info here on tunning the duratec from sbd,
Link
http://www.sbdev.co.uk/History_files/History_DuratecTuning.htm
I had a Westfield with a duratec it was 255 bhp and would pull 140 mph easily but it depends on your gearing and I presume you will fit a type 9
gearbox?
It will be a quick car and they look a nice install
Remember to modify the sump or fit dry sump for track use
Other options is a black top zetec you can pick them up cheap brand new and with some cams etc you can see near 200 bhp a good option for a brand new
engine I've seen them for £750
Best of luck with the build I do like the Indy I've had a few
Surrey Dave
posted on 18/12/14 at 01:48 PM |
Caterham
Could you buy a Caterham for that cash?
Much better investment and residual value, kits generally only go one way in value.
Calzonii
posted on 22/12/14 at 12:10 AM |
INDY yeah fitting it with a type 9 gearbox cause theyre easy to install to make a change from FWD to RWD.. Also why do you need to modify sump for
track use? just too much heat involved ive heard that dry sump systems are expensive?
Dave was looking at caterham before but i think id go for caterham after ive built one cause ill be making a fair few mistakes first time round and
caterhams prices are so expensive those mistake could be costly So were planning on using the MK for a jointbuilt hopefully not to expensive for
the time invested into it and then sell and move on to something better after a few years of enjoying it..
Anyone have any ideas where to pick up a duratec engine donor car and a decent price?
FASTdan
posted on 22/12/14 at 09:15 AM |
We run a 2.3 duratec on bike carbs in our indy, makes about 190bhp and is very potent (great torque too so pulls from nothing in every gear).
You will need to do something with the sump as it is a FWD engine as standard so is not baffled correctly for an inline install and is also far too
deep so needs shortening (ground clearance problems). So you either do as we did and shorten it, widen it and baffle/gate it (all ok if you have alu
welding equipment), make a new one in steel or fork out for a raceline or similar item.
Other big expenses are the mating to the type 9 (or similar) gearbox as you need a new bellhousing, flywheel etc.
The duratec isn't the simplest or cheapest (go zetec for this) but is a nice lightweight reasonably modern lump that gives good power easily and
has huge tuning potential.
We do a set of engine mounts for the duratec that will go straight into an indy btw so if you need these drop me a message.
NEW danST WEBSITE NOW LIVE! Bike carbs, throttle bodies and more......
http://www.danstengineering.co.uk/
