New Topic New Reply
Author: Subject: mk steering rack
MK9R
posted on 26/2/03 at 08:13 AM Reply With Quote
mk steering rack
Just to check i'm taking the correct part up on friday to exchange, does the MK Indy uses a modified sierra rack or escort MKI/II?
Thanks in advance.
bob
posted on 26/2/03 at 09:42 AM Reply With Quote
AUSTEN
Its the sierra rack you need,MK shorten it by a few inches.
philgregson
posted on 26/2/03 at 03:29 PM Reply With Quote
For definative answer I suggest contacting the MK steering rack owners club.
Phil.
B3Saxo
posted on 26/2/03 at 10:57 PM Reply With Quote
The sierra stearing rack is required.
Remember to bring the extension piece that sits on top of the rack. The piece thats about 10" long and has the clamps each side. The name is on the tip of my tounge!
I forgot mine but was given a piece to lengthen it myself.
Another quality post from B3Saxo!
dodgyroger
posted on 28/2/03 at 03:05 PM Reply With Quote
MK will extend your intermediate shaft as well as shortening the rack.
Beware though that there are two types of intermediate shaft, one can be extended, one cannot.
You need the earlier type which is a 10" unit with a 8-10mm dia shaft with UJs at either end.
My 'G' reg 1.8L Sierra had a later collapsible type that cannot be modified by MK. MK forgot to tell me this so to avoid disappointment, make sure you acquire the correct type to take with you.
Roger
http://www.dodgyroger.com/locost
New Topic New Reply
