Gareth
posted on 20/6/03 at 05:49 PM |
MK Indy Uprights and Steering
What does MK actually do to the Sierra Uprights and Steering rack? Is it just widening the bottom hole in the upright, and would it be better to use
an Escort Steering rack over a modified Sierra item?
Gareth
chrisg
| posted on 20/6/03 at 06:27 PM |
I believe it's magic!
The rack body is shortened and the arms extended with a screwed on "piece"(welding is a no-no on track rods for SVA and MOT)
Using the modded Sierra rack eliminates bump steer.
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the
error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
mad-butcher
the steering rack outer casing is shortened, the rack itself is shortened(not a hacksaw job then retapped with the kit you get a pair of extensions to
bring it back up to standard sierra track, this is all to do with bump steer and i'm not getting involved in that subject I know f all about the
subject all I know is martins done the sums and you won't get any dimensions off me and I doubt off any-one else Martins had too many of his
ideas ripped off just read some of the posts.. the top of the sierra upright has an exentric (just like martin) sleeve so you can alter the
camber/caster angle
regards
Tony
mad-butcher
| posted on 20/6/03 at 06:34 PM |
seems we posted at the same time. thanks for the info I'll have to grind the 2 tacks off
tony
Northy
| posted on 20/6/03 at 08:52 PM |
I've seen a car thats been through SVA with the tie rods modded and welded.
Graham
Stu16v
| posted on 20/6/03 at 09:27 PM |
Whats the difference between making your own wishbones and welding your track rods???
chrisg
| posted on 20/6/03 at 10:37 PM |
Dunno mate, I didn't write the book.
Chris
Macca
| posted on 20/6/03 at 11:06 PM |
About 3 hours!!!!!!!!!
Sorry
Stu16v
| posted on 20/6/03 at 11:36 PM |
Gareth
posted on 23/6/03 at 11:17 AM |
Cheers for the answers, looks like I will go for the basic kit rather that just by the chassis and wishbones.
Need to finish the garden first though, as that the agreement with the better half.
Gareth
