mad-butcher
| posted on 17/7/03 at 07:13 PM |
electronic speedo pickup
using tripode joints and drum brakes the option for the pickup for an electronic speedo seems to be magnets as you can't use the bolt heads of
the lobro type
My question is if I got chris PTM to make up a short length of tube with a flange made out of 9mm plastic welded to the tube and then held on by 3 or4
self tappers to the outer tripode cover I could then tap the flange to mount 6 short bolt heads. would this idea throw the balance of the shaft out to
much
Tony
theconrodkid
| posted on 17/7/03 at 07:26 PM |
i mounted my pick up under the prop u/j
depends on how many sensor points u need could use u/j ears or a disc between prop n diff with flags on it
who cares who wins
pass the pork pies
mad-butcher
| posted on 17/7/03 at 07:56 PM |
cheers for that I thought it had to be mounted on the drive shaft for calibration.
what make speedo are you using
Tony
theconrodkid
| posted on 17/7/03 at 08:05 PM |
its a racetec from raldes,no distructions so amount of flags to be determined yet,im working on it
who cares who wins
pass the pork pies
Rorty
| posted on 18/7/03 at 01:28 AM |
I encountered a similar problem before, and all I did was to glue the magnets on with some of the thick, gap-filling type super glue (Hot Stuff -
green label springs to mind). Just to be on the safe side, I wrapped some of that glass fibre reinforced clear sticky tape around the magnets just
once (so as not to interfere with the air gap).
The tape disapeared at some point (don't think I overlapped it enough), but the magnets stayed put!
Cheers, Rorty.
"Faster than a speeding Pullet".
PLEASE DON'T U2U ME IF YOU WANT A QUICK RESPONSE. TRY EMAILING ME INSTEAD!
