greggors84
| posted on 30/8/03 at 11:28 AM |
Rear Disc Uprights (and Hubs)
Has anyone got a picture of rear disc uprights from MK, as i think they have given me the wrong ones, they said there should be a cutout on one side,
which i cant see. If anyone could give some advise i would be grateful.
Also how do i get the rear hubs off the sierra, do i have to undo the central nut in middle of the hub, and if so whats the best way of keeping the
hub still while i unbolt it?
Chris
The Magnificent 7!
colibriman
| posted on 30/8/03 at 01:30 PM |
wish you had sent this yester day..i fitted my second hub onto the upright last night..so you wont really be able to see it..the plate on the upright
with the threaded bolt holes will be positioned at an angle...(if its a drum rear they are straight)..i didnt notice a cut out on mine...
pics if you need them tho...but i dont think they would help much..
yes the hub nut needs to come off..get this biggest vice you can find to hold the shaft....remember to look atv the thread direction...one side is a
reverse thread
have fun....
colin
| posted on 30/8/03 at 06:20 PM |
Best way to undo the nut is while the car is on its wheels with a bloody great bar. The socket is a special unless you have 3/4 drive and the torque
setting for it is 185 to 214 lbs ft. Nearside is left hand thread if I remember correctly.
yours, Pete.
[Edited on 30/8/03 by Peteff]
bob
| posted on 30/8/03 at 07:33 PM |
In me archive there should be a pic
