Guinness
| posted on 1/11/07 at 08:39 AM |
MK Pedal Box / Clutch Cable
I have just snapped my clutch cable. At the minute I have been using a mountain bike brake cable, and it looks like it has been rubbing on the edge
of the tube welded into the footwell.
Is the Indy designed to use a standard Sierra clutch cable?
Am going to try to modify a car one, hoping that the rubber / plastic section at the end fits down the tube and will stop the chaffing!
Mike
donut
| posted on 1/11/07 at 09:27 AM |
I have a Capri one that looks the same as what i used on both my Pinto Indy's. The ends are the same but you can get them in 5 different lengths
so i suggest going to your local motorfactors with the cable you have and see what he's got that will work.
cryoman1965
| posted on 1/11/07 at 11:13 AM |
Try a MK 2 escort clutch cable.
N
| posted on 1/11/07 at 12:55 PM |
I've used a Capri clutch cable too - the plastic end fits neatly inside the metal tube on the footwell. It also has an integral threaded
adjuster which makes setting up a doddle. Try looking through the Burton Power website for ideas.
Guinness
| posted on 2/11/07 at 05:59 PM |
Right, I got the cable today, but how did you guys connect it to the pedal?
Mike
