New Topic New Reply
Author: Subject: Exhaust fouls brace
Pezza
posted on 12/12/07 at 04:57 PM Reply With Quote
Exhaust fouls brace
Got my engine in today.
Alas when i tried to fit the manifold it fouled the round tube diagonal
Now I don't want to cut out the cradle and it's associated brace.
Can this diagonal be removed without weakening the chassis too much?
Do the bike engined chassis have this brace? Or have I spaced the cradle wrong?
Ben
You couldn't pwn your way out of a wet paper bag, with "PWN ME!!" written on it, from the "pwned take-away" which originally contained one portion of chicken tikka pwnsala and the obligatory free pwnpadom.
ditchlewis
posted on 12/12/07 at 05:04 PM Reply With Quote
i used the mk manifold which exits over the top rail. expensive i know but it looks ok.
ditch
Opps ignore this you are using a different engine, getting late in the day and its been a hard day
[Edited on 12/12/07 by ditchlewis]
matt_claydon
posted on 12/12/07 at 05:07 PM Reply With Quote
If you can weld, replace the single diagonal with two in a 'V' shape. Don't just remove it, I'd say it's pretty fundamental to preventing the engine bay folding in half!
[Edited on 12/12/07 by matt_claydon]
jacko
posted on 12/12/07 at 05:14 PM Reply With Quote
Cut the round tube at the front / top bend it down and re-weld to miss the manifold have a look in roadrunners photo archives i did his + tim windmills cars on here
Jacko
Pezza
posted on 12/12/07 at 05:17 PM Reply With Quote
Cheers chaps
martyn_16v
posted on 12/12/07 at 05:44 PM Reply With Quote
I had the same problem when I trial fitted my exhaust manifold, it goes on but it's touching that tube. I was thinking along the lines of trying to lean my engine over to one side a bit, or failing that 'relieve' the exhaust a little with the no1 tool...
mark chandler
posted on 12/12/07 at 06:43 PM Reply With Quote
A bent tube is a pre-crashed one as they say.
You need to cut it out, then make up a Y brace as above, you will then have plenty of room and not weakened the chassis.
Takes 1/2 hour when you are this stage of the build.
Regards Mark
New Topic New Reply
