jonesier1
| posted on 1/1/08 at 04:13 PM |
17"s ?what offset
hi,thinking of putting 17s on my indy can anyone suggest what ET i should use. thanks
repper
| posted on 1/1/08 at 04:21 PM |
ive got the specs for my viento if it helps
jim
[Edited on 1/1/08 by repper]
indykid
| posted on 1/1/08 at 04:42 PM |
et38 7"wide wheels will fit with 205 tyres.
you'll need to take all the return off your back arches though.
as most will say though, if you're still at the thinking about it stage, don't!
if i had my time again i'd build around 13" wheels, 15" at a maximum. 13s don't exactly suit the slightly taller indy sides
compared to a locost, but will make it much more pleasant to drive. tyres are cheaper and lighter, wheels are lighter and you have more choice of
proper performance tyres.
if i had the money and time, i'd go to 13" wheels on mine, but i'd need to remake the cycle wing stays and the set i have took long
enough to make! the back arches would probably want fiddling too.
hth
tom
[Edited on 1/1/08 by indykid]
jonesier1
| posted on 3/1/08 at 09:55 PM |
17s
thanks, already got some tyres so thought i would make use of them.
gingerprince
| posted on 4/1/08 at 11:20 AM |
If the only reason you're going for 17's is because you've got some tyres, then can I suggest you: -
- sell the tyres on fleabay
- buy some 13 or 15 wheels with suitable tyres
Yes you may have some tyres now, but eventually you'll wear them out and need more - and they'll cost a premium.
Unless you're particularly going for aesthetics then ditch the tyres
