New Topic New Reply
Author: Subject: Body Panels
Stuart_B
posted on 23/1/08 at 05:52 PM Reply With Quote
Body Panels
hi, how do i fit the side panels, scuttle, nose cone and rear panel??
thanks
Stuart
indykid
posted on 23/1/08 at 06:07 PM Reply With Quote
your scuttle wants to be fastened into rivnuts in the side rails. 3 each side helps get the sides straight and flush with the side panels.
side panels should be stuck on with polyurethane adhesive
nose cone either bolt on into rivnuts, or hinge on the lower edge and hold the top down with the the bonnet.
rear panel......polyurethane it on. you can stick a few rivets in too if you really want
tom
turbodisplay
posted on 23/1/08 at 07:11 PM Reply With Quote
My brother helped me on sat. to glue the rear bodywork section in place. He thought it was a bit of a bodge using polyureathane adhesive, until he got some stuck onto his hand!
New Topic New Reply
