vintagebuilder
| posted on 26/11/03 at 12:52 PM |
Dampertech Offer
Afternoon All,
I,ve been looking at the Dampertech offer of 4 dampers and springs for £250. In the MK build manual it says that the rear springs are rated at 200lb
and the fronts are 350lb. Further on in the manual it says the fronts are 300lb.If I order from Dampertech which do I need?
Does anyone know of a retail outlet that sells silicone grease for the Poly bushes, can't find anyone local.
Regards
greggors84
| posted on 26/11/03 at 04:28 PM |
We got 200 on the back and 350 on the front with the kit. It depends on what engine you have in the front as obviously a pinto weighs alot more than a
bike engine. We have a pinto by the way.
Also we used Castrol CL grease, it is a chassis grease and im guess ok for the bushes. I hope so as they are firmly in the wishbones and on the car
now! You can pick up 500g pots of it from Halfords.
Chris
The Magnificent 7!
mangogroove
| posted on 26/11/03 at 06:05 PM |
which offer is this?
SPECIAL - IN STOCK NOW!
Spring & damper set to fit self build Locosts, factory build Locosts (all companies)
Comprising of:
4 x 2 1/4 I/D Zinc plated fully adjustable coil over dampers with 3 years warrenty
4x 2 1/4 I/D Zinc plated fully adjustable coil springs
ONLY £330 including VAT & CARRIAGE
or
4x1.9 I/D (17/8" Units with springs and 3 years warrenty
ONLY £300 including VAT & CARRIAGE
vintagebuilder
| posted on 26/11/03 at 06:51 PM |
Hi,
It's the offer in this months Which Kit mag.
"Attention Locost Builders"
4x1.9 Gaz adj coil over dampers plus 4x1.9 quality powder coated springs, inc carriage and VAT.
Mk-Ninja
| posted on 26/11/03 at 07:01 PM |
As greggors say it must be too do with the engine you fit and thus the sprung weight. I got 200 for the back and 300 for the front using a ZX9R bike
engine.
I'm sure I've got one, just don't know where I've put it
ainsml
| posted on 27/11/03 at 03:34 PM |
if you give him a ring he will tell u what spring rates u need.
