New Topic New Reply
Author: Subject: Build sequence: engine first???
Mave
posted on 12/5/04 at 07:11 PM Reply With Quote
I can't decide on whether to put the engine/gearbox in right after I have mounted the floor (yep, I'm not even at that stage...). I'd like to do it a.s.a.p. just to get it off my chest, but I'm currently still trying to find some parts to be able to connect the two....
Are there any pro's/con's to putting the engine in when the whole suspension is already mounted, complete with brakelines etc.?
ray.h.
posted on 12/5/04 at 08:00 PM Reply With Quote
Miost of my build has been done with engine in. Ive found it helps when locating everything else. Obviously put the floor in first cos its damned heavy to turn over with the engine in.
posted on 12/5/04 at 09:12 PM Reply With Quote
That sounds really painful. It's easier to fit the stuff round the engine with it in than trying to predict where it's going to go before it's fitted. My engine was in and out like a fiddlers elbow before the final resting place was decided. Not an Indy but the principle must be similar.
[Edited on 12/5/04 by Peteff]
zetec
posted on 13/5/04 at 05:38 AM Reply With Quote
If you can I would "try" fit the engine and gearbox, mark where you want to run brake pipes/fuel lines/wiring and then remove it to do this work as it gives more room to work. Also if you have the chassis on a stand 3" off the ground to make life easy it is far easier to lower it to the ground without the weight of the engine.
bob
posted on 13/5/04 at 07:36 AM Reply With Quote
I'm with zetec on this one,when my car was at rolling chassis stage i hung eng and box in to mark out space.
The empty engine bay made it much easier to fit the brake lines and master cylinder,i also pre drilled some holes for the cable tie holders so the loom was easier to fit.
Mave
posted on 13/5/04 at 04:00 PM Reply With Quote
Thanks for the responses. My mastercylinders are already in place, and I've lined up the brakelines temporarily according to pictures of other Indy's, so they should be o.k. (fingers crossed.
But I can safely assume that building it to rolling chassis stage can easily be done without the engine in.
That buys me some time to find a 1.8 flywheel and Zetec wiring-loom.....
sebastiaan
posted on 13/5/04 at 08:37 PM Reply With Quote
Erm, sorry Marcel, but i put the engine in before even rivetting on the floor (trial fot of course) and i'm damn glad i did. With my car being left hand drive (as yours!) we had quite a lot of problems with parts fouling on the steering shaft. We found that we could get away with most problems, but it certainly took some tinkering.
For those wondering: on a Pinto, both fuel pump and oil filter are the main offenders.
Also take care about the length of your propshaft! this will define the longitudinal position of the engine if you buy an off the shelf item. If not, just put the engine as ar back as possible (see Siert vos's website for details)
Regards,
Sebastiaan
ps. is het niet lollig om dingen op een forum te typen die 99% niet kan lezen
posted on 13/5/04 at 11:14 PM Reply With Quote
Wir konnen mehr als Sie wissen lesen.
Nous comprennons plus que vous pensez.
What does lollig mean? I would guess it means stupid or funny, am I close?.
[Edited on 13/5/04 by Peteff]
sebastiaan
posted on 14/5/04 at 12:53 PM Reply With Quote
Lollig means Funny, Pete.
Those dictionaries must come in handy
Locostbuilders seems to be getting more and more mondial by the day! (spain, portugal, holland, germany, UK and more!)
redeye
posted on 14/5/04 at 02:09 PM Reply With Quote
i bought my kit at rolling chassis stage second hand
put the engine in soon after
but even then founf it difficult to fit brake pipe and m/c with engine in the way
might be better to locate engine near start of build and then take it back out
just a thought
Mave
posted on 14/5/04 at 03:53 PM Reply With Quote
I'm mounting a Zetec, where the oil filter is on the other side. And I've got my propshaft already, so the position of the engine is more or less defined.
The thing is, I've got lots of engine/gearbox issues to solve before I can put them in the car. But I would like to go ahead with my build in the meantime, which is why I'm asking.
And Sebastiaan; throw me some pictures of your MK!
Jonte
posted on 19/5/04 at 08:47 AM Reply With Quote
Just wondering on the fuel pump...mine is at the back with the fueltank. But as you say the oilfilter is a bugger. I´ll place my a bit away from it´s original place.
/Jonas
Currently in Guangzhou - China
Regards,
Sebastiaan
Click it
New Topic New Reply
