New Topic New Reply
Author: Subject: R1 performance in indy R
-matt
posted on 4/5/10 at 12:15 PM Reply With Quote
im looking at building a MK Indy R and am thinking of fitting a R1 motorbike engine. with the sierra diff.
can anyone who has done this tell me what sort of performance to expect.
0-60?
top speed?
cheers,
matt
mads
posted on 4/5/10 at 12:19 PM Reply With Quote
it's kind of an open-ended question as it will depend on a number of factors:
- engine age
- any engine mods
- rolling road performed
- diff ratio used
- weight of final car
I am building a 2008 R1 Indy R. Stock engine should give me around 170bhp. Wont know speed/acceleration til its built but I hoping for 0-60 in under 4.5s and a top speed of around 130 (but this is diff dependant).
We gain knowledge faster than we do wisdom!
Life is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body, but rather to skid in sideways, thoroughly used, totally worn out and loudly proclaiming... "f*ck, what a trip!"
TimC
posted on 4/5/10 at 12:30 PM Reply With Quote
Seems reasonable enough.
posted on 4/5/10 at 12:39 PM Reply With Quote
I had an MK with a 2005 R1 engine in it and I'd say those figures are just about achievable.
It's Evolution Baby!
mrwibble
posted on 4/5/10 at 12:46 PM Reply With Quote
if u haven't already bought a sierra diff, i think some people use freelander diffs as its lighter and the ratio is better for a bike engine?
TimC
posted on 4/5/10 at 01:00 PM Reply With Quote
TRUE
if u haven't already bought a sierra diff, i think some people use freelander diffs as the ratio is better for a bike engine?
It is dangerous to assume that this is correct in all cases but most MY R1 engines do work reasonably well with the 3.21 ratio assuming tha the tyres aren't too big.
iank
posted on 4/5/10 at 01:11 PM Reply With Quote
Freelander diff doesn't come with an LSD and AFAIK there isn't an aftermarket LSD available.
So if you feel you need/want and LSD Sierra is the way to go.
Anonymous
-matt
posted on 4/5/10 at 01:17 PM Reply With Quote
cheers, i haven't bought anything yet.
im still researching what im going to have to buy.
is it possible to change the ratio on the sierra diff's?
and what would the best ratio be?
ideally im looking for around 0-60 in around 4.5 secs and a top of at least 130.
also is it possible/easy to get much more power out of the R1 engine?
TimC
posted on 4/5/10 at 01:32 PM Reply With Quote
Not true. Quaife do one but they are not cheap.
On a Sierra diff, I'd say you want a 3.38 which again won't be cheap.
Have a look at this thread. It should help to answer some of your questions about ratios.
Originally posted by -mattalso is it possible/easy to get much more power out of the R1 engine?
No, get a Power Commander and if you want more the only thing really worth doing is fitting a turbo.
iank
posted on 4/5/10 at 01:39 PM Reply With Quote
Fair enough, they must have started making one once people started fitting them.
Anonymous
A1
posted on 4/5/10 at 02:50 PM Reply With Quote
ive got a 3.92 sierra diff on a 03 r1, ive reworked the head a bit and got a powercommander, iridium plugs (they claim to help acceleration) and filters. it pulls easily to 110, but feels like it could go a lot further. acceleration is immense, i think in the 3. something kinda range going on rough timing.
fesycresy
posted on 4/5/10 at 03:15 PM Reply With Quote
Are the ratio's different from the '03 and the later models? My '03 ran a 3.62, which for the road (unless cruising) I think was ideal.
However, I think a 3.38 may have been better, especially for the track, where higher maintained speeds would be an advantage. A 3.38 with an ATB would be very nice.
Freelander, well I've heard many problems over on the WSCC, so much that Westfield stopped using them. Again I'm not sure how reliable the later ones are.
Want more power? Fit a ZX12 / ZX14 / Busa from the start.
I'm suprised none of the CEC gang have suggested a pinto yet
adithorp
posted on 4/5/10 at 06:55 PM Reply With Quote
Freelander diff is OK with R1's upto '03. From '04 onwards the R1 has a higher final drive. Mine gets to 72 in first and tops out (theoretically) at around 150. In the Fury it's fine (still accelerating hard at 135) but you'll be hard pressed to get use of the top of the rev range in 6th, due to the poorer aero.
Sierra 3.38 would be fine in a seven. Will give you 0-60 around 4secs depending on weight and top out around 125ish. Try the gear checker sticky thread to get the figures.
adrian
http://jpsc.org.uk/forum/
New Topic New Reply
