-matt
posted on 2/6/10 at 05:36 PM |
Indy R Build parts?
Well i have decided i am going to build a R1 engined Indy R.
now due to limited space and funds im looking to buy the bits seperatly rather than in the big kit, and buy as i go.
obviously my first task is to buy a sierra and strip it down for all the donor parts.
then i will be looking at buying a big batch of parts from MK, and looking at getting all the parts for the suspention and steering done. (to keep me
busy for a couple of months).
now i have a big list, but can anyone confirm if ive missed anything off it that will be needed:
R chassis
R push rods
R rockers
R needle roller bearings
R rose joints
R rose joint shocks
shocks/springs
ball joints
track rod ends
track rod and extensions
front wishbones
rear wishbones
rear uprights
steering column extension
bush set
nuts/bolts/inserts
mushroom inserts
and the following modified:
front hub and upright
steering rack
steering UJ
cheers,
matt
gavin174
posted on 2/6/10 at 05:45 PM |
Hi Matt
welcome to the madhouse
where abouts are you...
might be able to help with a donor.
jack_t
posted on 2/6/10 at 05:50 PM |
all that will take about 3 hours to put together
mad-butcher
posted on 2/6/10 at 07:14 PM |
Think you'll find there's a big difference in price between buying a kit and buying it all seperately
tony
Coopz
posted on 2/6/10 at 08:11 PM |
If i was starting again I would buy the deluxe kit from kit then source everything else my self.
-matt
posted on 2/6/10 at 09:05 PM |
cheers for the advice.
im from gloucestershire.
as for buying the deluex kit, ive done my sums and there is not that much price difference, and TBH i really don't want all the body panels
laying around where they might get damaged, i would rather leave them till i need them.
also i will probably order more than ive listed, that is just a rough list to make sure i haven't missed anything major.
also i like to take my time with things like this, and by the time ive painted and protected the chassis Etc i won't be far off 2 months. then i
will have another load of cash to spend on another batch of parts
[Edited on 2/6/10 by -matt]
