silky16v
posted on 10/6/10 at 11:37 AM |
quick rack for MK Indy
Is it a simple case of buying a quick rack kit and swapping it over, or do i need to have the rack modified again to allow fitment.
I currently have the sierra rack with 4.5 turn to turn which is already modified by MK
i've seen the kit i i need from Rally Design and can do the work myself
jossey
posted on 10/6/10 at 11:41 AM |
yes you can get rack extensions to add to the quick rack and then just fit and your off.
should be simple.
you maybe able to by a quick rack with the arms at the right length.
silky16v
posted on 10/6/10 at 11:42 AM |
should be simple.
so i take it i can just use the arms i have fit them to the quick rack and that will be that?
austin man
posted on 10/6/10 at 11:46 AM |
is the quick rack designed for a seven ? if not you will have to cut it down and have 1 end drilled and tapped to allow you to fit the track control
arm. a local engineer will be able to do it.
[Edited on 10/6/10 by austin man]
silky16v
posted on 10/6/10 at 12:03 PM |
arh ok i've contacted MK twice but had no reply yet
posted on 10/6/10 at 05:29 PM |
Like Austin Man says, you can buy the quick rack internal but it would need to be cut down, re-drilled and tapped. I'd doubt that it would be
pre-cut to length, as all sevens are different and the length of the rack is critical to avoid bumpsteer.
You can then simply remove the old rack from the housing and replace with the quick rack. Pictures and words...........
Phil
[img][/img]
