neo2
posted on 15/6/10 at 07:05 PM |
MK indy seat mountings ??
Took my seats out today to swop belts over and stuff like that, and have noticed something im not too keen on to be honest with my indy...
Basically the seats bolt through the floor in each corner into the aluminum floor and that is it, so the seat is only secured to the car via 4 x bolts
through into a 3mm or so aluminum sheet..
I had a westfield and other kit cars all as far as i can remember the seats bolted through chassis rails or cross rails as part of the chassis
structure..
Is bolting a seat into a aluminum sheet good enough do you think i assume it is as thats how MK must make them but im a bit supprised thats all, whats
your thoughts guys..
Rob..
austin man
posted on 15/6/10 at 07:08 PM |
there is usuall a couple of steel strips across the chasis, which you drill and mount throug. Not sure if you have a really early chasis. To counter
this you can also use a large washer / metal plate to spread the load
eddie99
posted on 15/6/10 at 07:11 PM |
I personally would weld in a bar if i was you. Would prefer something a bit more substantial!!
http://www.elitemotorsporteng.co.uk/
Twitter: @Elitemotoreng
Facebook: http://www.facebook.com/pages/Elite-Motorsport-Engineering/153409081394323
sebastiaan
posted on 15/6/10 at 07:17 PM |
My 2004/2005 Indy chassis had some metal strips welded across the seating area to which the seats mount.
maybe they were deleted lateron? I'd prefer them to be there, but it seems MK have a habit of skimping on this kind of thing (remember the
sikaflex'd in fuel tanks....?)
neo2
posted on 15/6/10 at 07:27 PM |
Mines got cross rails in but no where near where seat holes are check picture below, you would need to be 2ft6" to sit in seat if it was mounted
through rails in this position
Guinness
posted on 15/6/10 at 07:31 PM |
Who built the car?
My seats are fitted through the bars shown in your picture. Certainly wouldn't pass an SVA / IVA with them just fitted to the ally floor.
Get the welder out and get another set of bars in, or fix another set longways, fixed to the seat and those rails. Could even mount some box section
underneath the floor?
Mike
peteday_uk@btinternet.com
posted on 15/6/10 at 07:32 PM |
My Indy R has the beams running across.
Pete.
Stuart_B
posted on 15/6/10 at 07:33 PM |
you could use seat runners
stuart
graememk
posted on 15/6/10 at 07:36 PM |
the early chassis didnt have the bars, i welded some in mine.
Staple balls
posted on 15/6/10 at 08:03 PM |
Yep, strips in mine too, 03 chassis. (I think)
neo2
posted on 15/6/10 at 09:05 PM |
Mk factory built race car mine is...
Yeah think i am going to add a few bars in to be honest,
Rob
Moorron
posted on 15/6/10 at 09:07 PM |
remember the seat belt takes the load in a crash not the seat, i understand your point but as long as you use large washers under the floor all is ok
IMHO.
if you have mk grp seats the threaded inserts would rip out way before the bolts would going thru the floor.
DRC INDY 7
posted on 15/6/10 at 09:08 PM |
mine is a 2006 chassis and has the metal strips my seats sit on box section which is then bolted through the steel strips
Puddle Dodgers Club
jabbahutt
posted on 16/6/10 at 11:19 AM |
As above I used steel box section bolted to the two strips and then mounted the seats to the box section. That gets away from the problem of the seat
being too far forward to utilise bolting directly to the strips.
hope that helps
Alan B
posted on 16/6/10 at 01:09 PM |
IMHO.
Although I probably would put some steel there to bolt them to, really the point made above is the key factor.
neo2
posted on 20/6/10 at 08:33 AM |
Yeah thats true the seat belt is whats going to be doing the work for sure good point there made about the MK GRP seat and the fixings pulling out,
it doesnt matter where or what you fix the seat too the seat fixings itself will be the weekest point wont it...
Still might fit some north south orientated runners to the existing cross rails for added security and less flex etc...as per jabbadahut's
comment..
bigpig
posted on 3/7/10 at 04:00 PM |
I've used the steel bars that MK put in (I'm 6'4" with seat runners. I've set the seats all the way back.
Without the runners, as you say, most people would be struggling to get in the car.
Going into ally, they will probably be enough body movement to start wearing the holes over the years (if not months).
procomp
posted on 9/7/10 at 01:17 PM |
Hi
3mm alloy floor. !!! I wouldnt worry. Looking at the picture you can see that the seat is sat on top of the two stringers anyhow so they are taking
the main weight under your backside. Use a washer the same thickness as the two stringers between the seat and the alloy floor so the seat is sat
level and not under strain on the mounting points in the grp seat.
What would concern me is whether the original builder has used rivets of the correct size to attach the 3mm floor. But assuming they are OK all looks
fine.
And there was me thinking that 1.6mm alloy floors where OTT on thickness.
Cheers Matt
neo2
posted on 9/7/10 at 09:09 PM |
Procomp my car was built by the factory fella MK themselves was a factory built race car for their publicity events and then sold to a mate of mine
then to me..
Rivets are the big type 10mm head on them..
procomp
posted on 9/7/10 at 09:46 PM |
Hi
It's not so much the diameter and head size that concerns me. It's the length. Considering it was a supposedly Factory built race car it
has to be asked why on earth they used 3mm for the floor. 1.6mm is the norm and 0.7 in NS4 or modern equivalent.
Cheers Matt
neo2
posted on 13/7/10 at 07:33 PM |
Second set of seat rails now welded in only took an hour feel happyier now
