Gaz4562
posted on 24/3/14 at 09:30 PM |
Mk 2 golf rad
Anyone know the oversize of a mk 2 golf alloy radiator. Or anyone used one. I know the core size. Cheers
adithorp
posted on 24/3/14 at 10:14 PM |
I've got one sat on my workshop floor at the moment. If you can confirm the core size you're talking about so we know it's the same
one, I should be able to measure the overall size in the morning.
If it is the same then I'm pretty sure it doesn't fit in an Indy nose.
http://jpsc.org.uk/forum/
Gaz4562
posted on 24/3/14 at 10:26 PM |
The core size is 430mm x 323mm x 40mm. I think it's only the length that is the issue. The ones mk use are 445mm overall.
adithorp
posted on 24/3/14 at 10:44 PM |
Pretty sure thats the one I use in the Fury. Fits 1.3 Polo and Golf. I found a slight leak in mine last Friday so swapped it this morning. I'll
measure the overall width in the morning.
Pretty sure MK (and other 7s) use the smaller 380mm core rad from 1lt Polo.
loggyboy
posted on 24/3/14 at 10:45 PM |
Im using one of these VW DERBY/GOLF/JETTA/PASSAT/POLO/SANTANA/SCIROCCO RADIATOR NEW - 2 YEAR WARRANTY
Slightly larger than 302 polo one used commonly.
Fits snuggly under the Raw nose
Mistral Motorsport
adithorp
posted on 25/3/14 at 10:31 AM |
540mm x 340mm overall.
